Progress Bar
Progress Bar
Hans_Redman
693件の閲覧回数
3件の返信
メッセージ1/4
Progress Bar
Hans_Redman
Does anyone know how to fix this problem? I want some like Image one, which is like has a progress bar at the top of the two buttons, but when I run the code it will look like Image two.
Here is the code:
import maya.cmds as cmds
import math
def windowUI(*args):
if cmds.window("progress_bar", exists=True):
cmds.deleteUI("progress_bar")
bar_window = cmds.window("progress_bar", title="Progress Bar", sizeable=False)
cmds.columnLayout()
cmds.separator(h=10, st='in')
#progressControl = cmds.progressBar(maxValue=100, width=300)
#cmds.separator(h=5, st='in')
cmds.rowColumnLayout(nc=2, cw=[4,2])
#Buttons
cmds.button("start_button", label="Start", w=149, command=start_part)
cmds.button("close_button", label="Close", w=149, command=close_part)
cmds.showWindow(bar_window)
def start_part(*args):
for i in range(10000):
for k in range(1000):
x = math.sin(math.sin(math.cos(i)))
if i%100 == 0:
cmds.progressBar(progressControl, edit=True, step=1)
def close_part(*args):
windowUI()
0 件のいいね
解決済み
694件の閲覧回数
3件の返信
返信 (3)
メッセージ2/4
Hans_Redman
Another question is how do you make the progress bar actually works? Not just go from 0% to 100%. Make it actually works.
Cheers
0 件のいいね
メッセージ3/4
Hans_Redman
解決済み
Fixed the first problem by use 'lambda x:' :
cmds.button("start_button", label="Start", w=149, command=lambda x: start_part(progressControl))
import math
    cmds.columnLayout()
    #Buttons
def start_part(progress_bar):
        if i%100 == 0:
            cmds.progressBar(progress_bar, edit=True, step=1)
windowUI()
More information:
https://forums.cgsociety.org/t/python-passing-arguments-from-a-button-to-a-function/1573367/3
Hope this helps
0 件のいいね
メッセージ4/4
Hans_Redman
How to add a gap between buttons?? Something like the 3 buttons at the top.
0 件のいいね
