Problems with Python subprocesses from Maya GUI
Hi there!
I'm kind of desperate with a weird issue that just appeared suddenly without any particular reason/explanation. I'm pretty sure that this is related to something on our side, but I do not know what it is, where to look at and how to fix this. I double checked with IT and they tell me that nothing changed on their side neither.
So, I just hope if you guys could give me just some input that might help me giving some direction to where look into.
Here is my problem:
It started suddenly, yesterday after lunch time that I'm not able anymore to launch Python instances from within a subprocess launched from Maya in GUI mode.
I create a simple executable file that looks like this:
#!/usr/bin/env python
print("Hello World!")
Let's say, I save this file to '/tmp/test' and chmod it to 775 to make it executable.
I open Maya, and in the Python script editor, I use following code:
import subprocess
subprocess.call(["/tmp/test"])
# or
# subprocess.call("/tmp/test", shell=True)
And I get following in my terminal:
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
ImportError: No module named site
When I launch my system python, mayapy or any other software with a Python interpretor and execute the same Python code, I get my expected 'Hello World!' printed in my terminal.
Checking a bit internet about this strange error (that I did not see before), people talking about bad Python installations or corrupted virtual environments. But this cannot be the case on my side. I checked multiple Maya versions, and all fail the same way. There is no reason that suddenly, all our Maya installations are broken.
I tried as well to set PYTHONHOME to '/usr/bin/python'. In this case, I just get the import error of the 'site' module.
I tried as well to launch python in verbosity and got this:
# installing zipimport hook
import zipimport # builtin
# installed zipimport hook
# trying site.so
# trying sitemodule.so
# trying site.py
# trying site.pyc
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/MASH/scripts/site.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/MASH/scripts/sitemodule.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/MASH/scripts/site.py
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/MASH/scripts/site.pyc
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/camd/scripts/site.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/camd/scripts/sitemodule.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/camd/scripts/site.py
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/camd/scripts/site.pyc
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/substance/scripts/site.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/substance/scripts/sitemodule.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/substance/scripts/site.py
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/substance/scripts/site.pyc
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/xgen/scripts/site.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/xgen/scripts/sitemodule.so
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/xgen/scripts/site.py
# trying /opt/software/thirdparty/autodesk/maya/2018.4/plug-ins/xgen/scripts/site.pyc
I see that it tries to find the 'site' module. But I can import it in my Maya Python script editor, I can import it in my system python and mayapy.
So, if anyone could give me a hint, I would be happy.
Thanks for your time!
Greets,
Carlo
cgiesa
Observer
Observer
Just for the sake of keeping you up-to-date about this subject. We were unable to find out what exactly produced this situation. But we could find a work-around.
So, it seemed that somehow, the combination of our system Python installation and Maya did not work together. We started from a clean Python installation on our system and could then run again subprocess out of Maya without any problems.
I do not know what 'magic' Maya does that can eventually end up in really crazy behaviours of Python inside subprocesses, but well.
This post can be marked as solved.
Greets,
Carlo
lee.dunham
I experienced similar issues, and I cant remember whether it was related to PATH variable and conflicting libraries?
