problems upgrading maya
peyton4596
peyton4596
So I'm trying to upgrade my maya from 2015 to 2016 and since i got rid of the maya 2015 app and downloaded the 2016, maya doesn't want to open and has been giving me these errors every time i launch 2016 up. I really need help! I've already contacted agents from autodesk but they said it would take 24 hours to get back.!
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/startup/initChannelsLayers.mel line 342: Cannot find procedure "showLayers". //
// AbcExport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/muscle/cMuscle.mel line 519: menu: Object 'mainRigDeformationsMenu' not found. //
// AbcImport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// BifrostMain plug-in loaded (built Feb 26 2015 18:00:13)
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/addSelectTypeItem.mel line 115: Cannot find procedure "updateSelectTypeItemState". //
// Error: line 1: initializePlugin function failed (gpuCache) //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 46: initializePlugin function failed (gpuCache) //
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem". //
// Error: file: /Applications/Autodesk/maya2016/plug-ins/xgen/scripts/muAddShelfButton.mel line 114: Object '' not found. //
updateRendererUI;
mspeer
Hi!
Make sure to install the latest Service Pack available for your Maya Version and try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
