Problem giving input connection to the per-particle attributes via custom nodes
I have written custom node, which generates positions for particles as vector array. Now I want to connect this output to the per particle position attribute but its not happening. Is that any other way to give a input for per particle attributes ? please help me out , thanks
Take a look at MPxParticleAttributeMapperNode
andrea_pinto82
I am trying to make an arraymapper with pyhton.
class arrayMapperCustom(OpenMayaMPx.MPxParticleAttributeMapperNode):
	# class variables
	outPositionPP = OpenMaya.MObject()
	def __init__(self):
		OpenMayaMPx.MPxParticleAttributeMapperNode.__init__(self)
when I create the node there are not errors.
but when I try to connect the attributes I have this warning. Why?
connectAttr -f arrayMapperCustom1.outPosition nParticleShape1.userVector1PP;
// Warning: line 1: Connection from arrayMapperCustom1.outPosition ---> nParticleShape1.userVector1PP was not allowed. You can only connect to a per-particle attribute from another per-particle attribute on the same shape or from an arrayMapper or particleAgeMapper node. This may cause subsequent connections to fail during duplication with the "-ic" flag. //
// Error: line 1: Connection not made: 'arrayMapperCustom1.outPosition' -> 'nParticleShape1.userVector1PP'. Destination node will not allow the connection. //
// Error: line 1: The attribute 'arrayMapperCustom1.outPosition' cannot be connected to 'nParticleShape1.userVector1PP'. //
andrea_pinto82
sorry, I had wrote wrong the registernode.
Now it is works
mplugin.registerNode( kPluginNodeTypeName, arrayMapperCustomId, nodeCreator, nodeInitializer, OpenMayaMPx.MPxNode.kParticleAttributeMapperNode )
andrea_pinto82
Hi, I have a problem with the class attribute "computeNode"
arrayMapperCustom.attributeAffects( arrayMapperCustom.computeNode, arrayMapperCustom.outPositionPP)
this is the error when I load the plugin
# Traceback (most recent call last):
# File "/Applications/Autodesk/maya2020/Maya.app/Contents/MacOS/plug-ins/arrayMapperCustom.py", line 156, in nodeInitializer
# arrayMapperCustom.attributeAffects( arrayMapperCustom.computeNode, arrayMapperCustom.outPositionPP)
# TypeError: in method 'MPxNode_attributeAffects', argument 1 of type 'MObject const &' //
// Warning: file: /Applications/Autodesk/maya2020/Maya.app/Contents/scripts/others/pluginWin.mel line 317: Failed to call script creator function //
Where am i doing wrong? Any ideas?
thanks
andrea_pinto82
I found it, sorry for my newbie ignorant questions. 🙂
computeNode = OpenMayaMPx.cvar.MPxParticleAttributeMapperNode_computeNode
