Problem Confirming Mesh Type
bayareadeck
bayareadeck
Working in Maya 2022.  This python code is not printing "mesh".
I don't get an error message either, just the repeated code.  ???
Is it a spacing issue ?
def currentSelection(obj):
       obj = cmds.ls(selection = True)
       shapeNode = cmds.listRelatives(obj, shapes = True)
       nodeType = cmds.nodeType(shapeNode)
       if nodeType == "mesh":
           print("mesh")
Kahylan
Hi!
You are just storing your function into Memory but not calling it currently.
You need to add:
currentSelection()
At the end, to actually execute your fuction. Also your kwarg "obj" in your functions definition is redundant because you immediately overwrite it.
I would probably define another attribute, like this:
selObj = cmds.ls(selection = True)or obj
This gives the user the ability to define the obj via string in when calling the function if nothing is selected.
I hope this helps!
bayareadeck
Ok, right of course.... like this ? it is compiling. Thank you!
def currentSelection():
    shapeNode = cmds.listRelatives(selObj, shapes = True)
        print("mesh")
currentSelection()
Kahylan
Exacly!
Have a nice day
