PRINT selected objects name
Richardd013
Richardd013
Hi is there a way to print the list of selected objects in Maya using python or MEL?
I'm looking for a way to automate this instead of copy-pasting them manually cause it'll save me some time.
I need to put the list of the objects in excel later on.
Thank you!
brentmc
The MEL command to list the selected objects is:
ls -sl
Brent McPherson
Principle Engineer
Richardd013
that worked! but how to make it printed verticaly instead?
brentmc
In that case you will need to loop over the selection and print each item followed by a newline:
    string $obj;
    string $sel[] = `ls -sl`;
    for ($obj in $sel) {
        print($obj + "\n");
You can do a lot in Maya with some simple programming skills so you should look for some introductory tutorials on MEL to get started.
Brent McPherson
Principle Engineer
