pass arguments to function called in textField "-enterCommand"?
I have an array of text fields, and when the user changes the values I need to call a function.  How do I let the function know which of the text fields was changed?  Does the 'enterCommand' argument take arguments itself?  I tried doing this:  -entercommand "textFieldChanged($i)" ,  where $i is the number of the text field.  But I get an error.  How do you pass arguments to the functions triggered by -enterCommand?
Thanks!
jmreinhart
def textField_command(passed_value):
    print passed_value
window = cmds.window()
cmds.rowColumnLayout( numberOfColumns=1)
cmds.text( label='Name' )
name = cmds.textField(aie = True)
ec_val = 'textField_command("{}")'.format(name)
cmds.textField(name, e = True, ec = ec_val)
cmds.text( label='Address' )
address = cmds.textField(aie = True)
ec_val = 'textField_command("{}")'.format(address)
cmds.textField(address, e = True, ec = ec_val)
cmds.text( label='Phone Number' )
phoneNumber = cmds.textField(aie = True)
ec_val = 'textField_command("{}")'.format(phoneNumber)
cmds.textField(phoneNumber, e = True, ec = ec_val)
cmds.text( label='Email' )
email = cmds.textField(aie = True)
ec_val = 'textField_command("{}")'.format(email)
cmds.textField(email, e = True, ec = ec_val)
cmds.showWindow()
Here is an example
jonsX942W
I wanted to learn this as well so I took a stab at it. Try this
import maya.cmds as cmds
#printedInput = (textField_command(fieldTexts))
#print printedInput
nameInput=""
addressInput=""
phoneInput=""
emailInput=""
def defaultButtonPush(fieldTexts):
    print fieldTexts
    controls = cmds.lsUI( controls=True, long=True)
    print controls
    #this finds the "MyWindows"
    myWindowCtls = [ctl for ctl in controls if ctl.find('MyWindow') == 0]
    print myWindowCtls
    #This finds all of the items with "textfield" in the name
    myTextCtls = [ctl for ctl in myWindowCtls if ctl.find('textField') != -1]
    print myTextCtls
    UserInput = [ (cmds.textField(text, query = True, text=True)) for text in myTextCtls]
    #print "name is" + nameInput
    print UserInput
    print 'Button 1 was pushed.'
    nameInput=UserInput[1]
    print nameInput
    addressInput=UserInput[2]
    print addressInput
    phoneInput=UserInput[3]
    print phoneInput
    emailInput=UserInput[0]
    print emailInput
window = cmds.window("MyWindow")
name = cmds.textField(aie = True,)
cmds.button( label='Enter', c = defaultButtonPush )
cmds.showWindow()
#textField_command(passed_value)
jonsX942W
Did this fix your Issue? if so can accept solution?
