Announcements
Open recent file hotkey
o.safonov82VMW
o.safonov82VMW
I need a command to open the last saved file. I want to open the last file by hot key
Kahylan
Its a bit hacky because it uses optionVar to read out the filepath from the UI of the recent files. There is probably a more elegant way to do this using the API. But this MEL script does what you want:
string $recent[] =`optionVar -q RecentFilesList`;
string $last = $recent[(size($recent)-1)];
file -o $last;
I hope it helps!
o.safonov82VMW
Thank you very much! I can spend more time with my family 😉
