Numpy 2018/2019?
Numpy 2018/2019?
Message 1 of 9
Numpy 2018/2019?
Anyone have a working compile of numpy for Maya 2018/2019?
I've seen a lot of posts with this link, but it doesn't contain numpy: https://drive.google.com/drive/u/0/folders/0BwsYd1k8t0lEfjJqV21yTnd2elVhNXEyTXhHclhxbDhvWVF5WWZUeVFI...
Unless I'm missing something here?
Replies (8)
Message 2 of 9
I have the same problem.
Many references to a pre-compiled numpy version for Maya 2018, which supposedly works for 2019 as well, but the actual file is nowhere to be found.
Any verified ways to get numpy working in Maya 2019?
Message 3 of 9
I believe I got numpy in Maya 2019 working now.
I followed the steps outlined below using the MSVC2015 64 bit compile of python 2.7.10. Installed pip, installed scipy (numpy was already installed in the python package). Copied the packages from python27/lib/site-packages into my Maya PYTHONPATH and done. Ready for action
https://forums.autodesk.com/t5/maya-programming/guide-how-to-install-numpy-scipy-in-maya-windows-64-...
Regarding the original question, then I found a Wheel file with the same name here:
https://www.lfd.uci.edu/~gohlke/pythonlibs/#numpy , following the guide here: https://blog.csdn.net/none123java321/article/details/77932224
However, I didn't manage to get it working with this method.
Message 4 of 9
Never mind the above, it didn't work anyway - missing DLL's when trying to import scipy.optimize
However, I DID get both numpy and scipy working and tested now.
I did the following (Windows 10, 64bit, Maya 2019):
1) Download get-pip.py and place it in the same folder as Maya's mayapy.exe
2) Open a terminal with admin permissions and navigate to mayapy.exe (ie: C:\Program Files\Autodesk\Maya2019\bin)
3) Install pip:
mayapy.exe get-pip.py​
4) Install wheel
mayapy.exe -m pip install wheel​
5) Install Maya-compatible precompiled numpy and scipy wheels from https://pypi.anaconda.org/carlkl/
mayapy.exe -m pip install -i https://pypi.anaconda.org/carlkl/simple numpy
mayapy.exe -m pip install -i https://pypi.anaconda.org/carlkl/simple scipy​
That should be it.
Message 5 of 9
I'm trying to do this for Maya 2020.  I am not sure where to locate get-pip.py.   The only one I can find throws errors when being run as described above, and from what I can tell, it's not compatible with python 2.7, so I don't understand how this ever worked.
Edit: okay, I found a version which worked (https://bootstrap.pypa.io/3.2/get-pip.py)
Also step 4 threw a bunch of errors but turned out not to be necessary.  Thanks!
Message 6 of 9
martinezalonsoAD2X6
Community Visitor
Community Visitor
Here were steps the helped me install numpy and scipy in Maya 2020 Mac:
  1. Download the get-pip.py file:
    A)   https://bootstrap.pypa.io/pip/2.7/get-pip.py
  2. Save the file in your desktop as "get-pip.py"
  3. Open a terminal
    1. run the following commands: (this will ask you for your password) (if not using maya 2020, change first line to your maya version)
      cd /Applications/Autodesk/maya2020/Maya.app/Contents/bin/
      sudo cp ~/Desktop/get-pip.py .
      ./mayapy get-pip.py
      ./mayapy -m pip install numpy
      ./mayapy -m pip install scipy
  4. ENJOY!
Hope that helps!
Message 7 of 9
dkqjwl0126
It's perfectly correct answer for me. Thank you guy. 🙂
Message 8 of 9
hossam.fawzy
Observer
Observer
Just an Update. as things have changed [A lot] Maya 2022
  • You can just install pip without the need to download any scripts
mayapy.exe -m pip install --upgrade pip
  • If you tried  "mayapy.exe -m pip install wheel​" You will see this unwelcomed guest
ERROR: Invalid requirement: 'wheel\u200b'
An Alternative is :
pip install --upgrade setuptools pip wheel
  • numpy now can be directly installed with pip
mayapy.exe -m pip install numpy
  • The same goes for scipy
mayapy.exe -m pip install scipy
Cheers,
Hossam
Message 9 of 9
jchampTBPRE
Observer
Observer
You nailed it, was going crazy trying every other method. Thanks.
