'NoneType' object has no attribute
 Hello, I'm new in Maya programming and I can't figure out how to fix this.
In the DevKit there is an example python plug-in called yTwistNode.py.
When I compile it in Pycharm I get an error on these lines:
outputGeom = OpenMayaMPx.cvar.MPxDeformerNode_outputGeom
envelope = OpenMayaMPx.cvar.MPxDeformerNode_envelope
The error says: AttributeError: 'NoneType' object has no attribute 'MPxDeformerNode_outputGeom'
Could you help me to understand what is wrong?
I think this is something I have to set in PyCharm, but I can't figure it out
RFlannery1
According to the following forum post, it should work if you change "OpenMayaMPx.cvar.MPxDeformerNode_outputGeom" to "OpenMayaMPx.cvar.MPxGeometryFilter_outputGeom". https://forums.autodesk.com/t5/maya-programming/openmayampx-cvar-mpxdeformernode-outputgeom-error/td...
Alternately, I found a post from an external site that suggests the problem may be solved by updating Maya.  It looks like there was a change introduced in Maya 2016 that broke the code.  But upgrading to Maya 2016 Service Pack 2 solves the problem.  http://discourse.techart.online/t/maya-2016-python-deformer-plugin/5239
I don't think the problem is the update, cause I have Maya 2018.
By the way, the entire code is this:
kApiVersion = cmds.about(apiVersion=True)
if kApiVersion < 201600:
else:
outputGeom = OpenMayaMPx.cvar.MPxGeometryFilter_outputGeom
envelope = OpenMayaMPx.cvar.MPxGeometryFilter_envelope
 So I don't think the problem is to change MPxDeformerNode with MPxGeometryFilter
RFlannery1
That's really strange.  Since you're in Maya 2018, kApiVersion should be getting a value of 20180000 or 20180100 (depending on if you have the latest update.)  Both of those numbers are greater than 201600, so the code should never even enter the part where it's trying to use MPxDeformerNode.
Maybe it's something specific to PyCharm?  I tried copying that bit of code into Maya's Script Editor and it ran without a problem.
Yeah, I've changed to Visual Studio and now it works... Thank you 🙂
