Ok, so then please explain to me, what EXACLTY do you need from me?
Because from your question it seems like you managed to lose your files on your own desktop, curious how that happend tbh, and you are now asking strangers on the internet to find the for you remotely. Or did I missunderstand you there?
In my first answer I explained to you how you easily can find a file you are working on on your harddisk, no matter where you saved it, and if you did not reset your project location chances are pretty big that you will find all your other maya files in the exact same location.
I also explained to you how you can change your save location to a place where you will find your files in the future...
And honestly please, if you don't have any CONSTRUCTIVE critique on how I might help you with your problem/explain to you how to solve your problem. Or any further explanation about your problem. Don't bother answering anymore. Your post gives insufficient information on your problem and you obviously can't be bothered with giving any more since you didn't answer any of my questions in my previous responses.
If you don't manage to find your files with the information I gave you, I would suggest you start over with your project and use the "save file as..." option to save your files this time (File->Save File As..., Shorcut: SHIFT + CTRL + S) and write down the exact folder you save in and the name you are giving your file on a piece of paper, so you don't lose the files again.
I hope this helps!
