Missing from Maya devkit MDagMessage::addMatrixModifiedCallback
negow
Message 1 of 8
negow
Putting this here for the next person searching for a missing devkit member. Missing from 2018, 2019 and 2020 devkits for both Windows or Linux.
- help.autodesk.com/view/MAYAUL/2020/ENU/?guid=__cpp_ref_class_m_dag_message_html#abf57819e7ef5d1badcc6adff5ba3f273
Replies (7)
Message 2 of 8
brentmc
What exactly do you mean by "missing"? Are you referring to the documentation or something else?
Thanks.
Brent
Brent McPherson
Principle Engineer
Message 3 of 8
negow
Sorry, I mean the documented member is missing from maya/MDagMessage.h
Here's a visual to clarify. 🙂
Message 4 of 8
brentmc
That method was introduced in an update release so if you didn't download a new DevKit that would explain why it is missing.
Brent
Brent McPherson
Principle Engineer
Message 5 of 8
negow
Hm, that doesn't sound right. It's documented since 2019, and is missing from 2020.2.
- help.autodesk.com/view/MAYAUL/2019/ENU/?guid=__cpp_ref_class_m_dag_message_html#abf57819e7ef5d1badcc6adff5ba3f273
Do you mean it got removed in 2020, and re-added in 2020.3 and above? Mind you, it is missing from 2019.3 as well.
Edit: Earliest I can spot it is in the devkit for 2021.pr118, if that helps!
Message 6 of 8
brentmc
That method was added in 2020.3. I know because I added it. 🙂
I think the 2019 doc entry is an error. I'm checking on why that is listed...
It is a brand new method that was added to supplement addWorldMatrixModifiedCallback which only picks up changes in parent matrices. If you add that to a transform you will not get called when the transforms matrix changes so we added a new callback for that case.
Brent
Brent McPherson
Principle Engineer
Message 7 of 8
negow
Great, case closed. 🙂 That also reflects what I was hoping to get out of the callback. Would be great with a note in the docs about when it got added. I really like the deprecation notes with mention of specific versions.
Message 8 of 8
brentmc
The 2019 docs have been corrected now. (if you flush your browser cache)
Thanks.
Brent
Brent McPherson
Principle Engineer
