(MEL) problem with reordering uvset script
absoluteKelvin
absoluteKelvin
   string $mesh[] = `ls -sl`;
   string $uvSets[] = `polyUVSet -q -allUVSets`;
   int $setNum[];
   //int $counter = 0;
   for ($i = 0; $i < size($uvSets); $i++){
       $setNum[$i] = int(`match "[0-9]+$" $uvSets[$i]`); //extract uvSet number
       if ($setNum[$i] != ($i + 1)) // if there is mismatch then run the following
           int $nuvSetNum = $setNum[$i] - 1;
           //print $nuvSetNum;
           polyUVSet -reorder -uvSet $uvSets[$i] -nuv $uvSets[$nuvSetNum]; //swap uvSets
           $uvSet[$i] = $uvSets[$nuvSetNum]; //update the uvSet array
           updateUvSetEditor;
this script is making the assumption that the uvSets are name with the same prefix (ie map1 map2 map3...)
what it is suppose to do is reorder the uvSets to numerical order.
example
map2
map3
map5
map1
map4
would become
map1
map2
map3
map4
map5
not sure where it went wrong in the script. any help is welcomed
https://www.artstation.com/kelvintam
mcw0
Don't know about the rest of the code.  But this is what I saw on initial inspection.
Shouldn't this
be
$uvSets[$i] = $uvSets[$nuvSetNum]; //update the uvSet array
absoluteKelvin
great catch mcw0. Now it works some times. but most of the time i run into this error
Error: line 13: Cannot reorder same uv sets. No reorder performed.
absoluteKelvin
interestingly after looking at the code in uvTkBuildUVSetsOptions.mel. I was able to get it to work somehow but not the way i want it to. the uvs get sorted after i run the code a few times.
   int $setNum[];
   //int $counter = 0;
       //$setNum[size($setNum)] = int(`match "[0-9]+" $set`)
           int $destIndex = $i - 1;
           while ($destIndex >= 0)
               polyUVSet -reorder -uvSet $uvSets[$i] -nuv $uvSets[$destIndex];
               $destIndex-- ;
       updateUvSetEditor;
       //$uvSets = `textScrollList -q -allItems uvSetList`;
