MFileIO open
MFileIO open
MFileIO open
On Maya 2017 on macOS -- I have a .ma file which standalone Maya opens just fine, but if I try to open it in my custom exporter I get kFailure from MFileIO::open. How do I troubleshoot this problem? Note, other Maya files work just fine, and this one is super simple (it just has a polyPlane in it) yet it fails.
cheng_xi_li
Autodesk Support
Autodesk Support
I am afraid there is no way to troubleshot it directly. But MFileIO::open actually uses file command to open a file, so I suggest you test with file command.
BTW: It would be better to use force flag with MFileIO::open, because if the scene is not saved, it will fail.
Yours,
Li
I am using "force". Plus, after much troubleshooting it turns out that from
FileIO::open I can't even open an empty .ma file, and of course in Maya if
I go File/Open it works fine. Could there be something in the .ma file
format itself that breaks it? Any help greatly appreciated.
cheng_xi_li
Autodesk Support
Autodesk Support
There shouldn't be any problem for .ma file.
If MFileIO couldn't work for you, please try to use MGlobal::executeCommand with file command, it is same as MFileIO.
Yours,
Li
Thank you very much for your reply. Can you please post the exact script command I should pass to executeCommand?
cheng_xi_li
Autodesk Support
Autodesk Support
Should be
file -open "filename.ma" - force;
You can find more details in this document.
Yours,
Li
This almost worked, the correct command is:
file -open -force "filename.ma"
Anyway, perhaps this should be filed as a bug, MFileIO::open should work identical to the command.
Thanks!
Emil
