(MEL)Why does polyEvaluate -uvShell give int array as result?
absoluteKelvin
absoluteKelvin
I can't figure out how to make use of if. When it clearly should give a integer. Because when I use it in my code I get silly syntax warnings about Cannot cast data of type int[] to int when casting it into a variable.
https://www.artstation.com/kelvintam
trs_andre
Well I guess you could always access $intArrayVariable[0] instead of $intArrayVariable .
Does it work in your case?
André Moreira
Game Developer / Technical Artist
LinkedIn
absoluteKelvin
global proc string [] KTgetUVShells()
   string $shellList[];
   string $objects[] = `ls -o -sl`;
   int $shellAmt[];
   int $num;
   int $shellIds[];
   int $counter = 0 ;
   for ($obj in $objects)
       $shellAmt[0] = `polyEvaluate -uvShell $obj`; // get amount of uvshells in object
       $num = $shellAmt[0]; // cast the shellAmt to num to be used in for loop condition
       for($i = 0; $i < $num; $i++);
           $shellIds[size($shellIds)] = $counter;
           $counter += 1;
       for ($s in $shellIds)
       		string $uvsInShell[] = `polyEvaluate -uis $s $obj`;  //gets the .map of the corresponding uv shell ID
		$shellList[size($shellList)] = stringArrayToString($uvsInShell, " "); //storing the uv shell into array
   return $shellList;
KTgetUVShells;
if you run this on a mesh selected it will give
// Error: line 11: Cannot convert data of type int[] to type int. //
trs_andre
IF you change to
$shellAmt = `polyEvaluate -uvShell $obj`; // get amount of uvshells in object
the error disappears. Does it help?
André Moreira
LinkedIn
absoluteKelvin
the error still appears for me if i run the code all together.
mspeer
Hi!
@trs_andre  is correct, if you change
$shellAmt[0] to $shellAmt
in this specific line of your example code, then it works.
absoluteKelvin
i must have messed up somewhere. It works now thanks for the help guys.
