MEL - Select Geometry ONLY within a selection
Hi Everyone,
I'm having trouble writing a MEL script that only selects geometry within a selection. For example: I have a hierarchy with groups, geometry, locators, 3d nodes, distanceDimensions, etc. I want it to select only the geometry within that selected hierarchy and nothing else, otherwise the script will error and won't continue on to the next portion.
Here's what I have so far:
// primary visibility TEST
string $selection[] = `ls -sl -s -dag`;
for ($node in $selection)
editRenderLayerGlobals -currentRenderLayer TEST;
setAttr ( $node + ".primaryVisibility") 0;
If I use 'ls -geometry'; it selects all the geometry in the scene, but I only want it to affect what is inside my selected hierarchy.
Thanks in advance,
The command you want is the listRelatives command.
Rallion, thanks for responding. I tried listRelatives briefly but it wasn't working. Once I have more free time I'll try it again.
Not sure with mel, but you could use list comprehension in Python.
Create 2 lists:
1)Selected Objects.
2)Geometry in the scene.
3)Combine the two if the match.
import pymel.core as pm
sel = pm.ls(sl=True)
meshes = pm.listTransforms(type='mesh')
selectedMeshes = [x for x in sel if x in meshes]
Hey there,
did you ever manage to create something that worked?  This is such a simple concept, I'm surprised I couldn't find this anywhere else on Google, for all specified type objects within hierarchies.
Yes I resolved it with the filterExpand command: https://help.autodesk.com/cloudhelp/2017/CHS/Maya-Tech-Docs/Commands/filterExpand.html
MEL Example:
string $selection[] = `ls -sl`;
string $polyGons[] = `filterExpand -sm 12 $selection`;
select -r $polyGons;
You can also do the same thing via Python:
selection = cmds.ls(sl = True)
polyGons = cmds.filterExpand(selection, sm = 12)
cmds.select(polyGons, r = True)
Hope it helps.
Awesome I will try them out.
A coworker also quickly cooked up this python script and it seemed to work fine:
import maya.cmds as mc
mc.select(hi=True, r=True)
hierarchy = mc.ls(sl=True, long=True)
shapes =  filter(lambda x: mc.nodeType(x) == 'mesh', hierarchy)
transforms = [mc.listRelatives(shape, p=True, fullPath=True)[0] for shape in shapes]
mc.select(transforms, r=True)
I believe the script pasted correctly.  Ot gave me an error when I tried to post about invalid html.
