Mel script....selection set to material assignment...
I need a mel script that will look at a meshes various face selection sets and use these set names to assign unique materials with that name to each set of face. Lets just say lambert for now but I eventually need it to apply VrayMtls but I think I can figure that part out. I have a mesh that comes into maya with a unique face selection set for each material. I just want to loop through those sets, taking their names, and apply a material to each set with that same name. This should be pretty simple but I cannot figure it out.
I think it should involve the listSets command and a for-loop but I cannot seem to be able to make an array of the sets to loop through. Mel freaks out every time I try to declare listSets as a variable.
How would I do this?
Ok, so I was able to make a string work:
string $sets[]=`listSets -as`;
This will deliver EVERY set in my scene. But I only want to be dealing with the ones in the set editor...the ones that show up at the bottom of the outliner. They each have a unique name but have a common suffix...so if there was a way to wildcard them that would work to define a new list of just the sets I want....but I don't know how to do that...
I thought on this some more and this is what I came up with:
for($s in $sets){
if(`objExists $s`){
if(`setFilterScript $s`){
if(!`gmatch $s "modelPanel*"`){
$newName=substituteAllString($s, "ncl1", "mtl");
$newMtl=`shadingNode -as -n ($newName +"_VRAY") VRayMtl`;
select $s;
hyperShade -assign $newMtl;
It seems to work pretty well in a fresh load of maya. It will scan the sets of an object that has a bunch of poly-face sets and apply a vray material to each set with the name of the set. The problem is that it doesn't seem to work unless you restart maya each time. I guess for now it does what I need it to do even if I have to restart maya each time although I'd love it to work better. If anyone with actual scripting experience has any input please let me know.
I bring models from modo into maya all the time and have been trying to come up with a good way to reshade them. This comes close but could be better...
