Create a universal action to disable double sided object.
I want to make this action to disable double sided of any object that I've selected.
setAttr "u041167412008Shape.doubleSided" 0;
I'm using Maya 2013.
Thanks in advance.
mspeer
Hi!
You don't need a mel script for this.
Use Attribute Spread Sheet -> Render
Select all objects values of Double Sided and enter "0".
For a mel script you first need to create a selection list and then iterate over it.
Only useful if you do this very often.
http://help.autodesk.com/cloudhelp/2017/ENU/Maya-Tech-Docs/Commands/ls.html
Actually I'm modelling products in their separate files so I have to use it for every product. That is why I need to make an action.
