Announcements
Mel script, is it possible to query if faces are selected on child geometry?
malcolm_341
Message 1 of 1
malcolm_341
I have a tricky problem. I need to create an error message in this condition and can't figure it out.
I have two spheres.
SphereB is parented under SphereA.
I select SphereA and enter face component mode.
But then, I select faces on SphereB.
I'd like to print true if any faces are selected on SphereB, and print false if faces are only selected on SphereA.
I've tried this for a day and I can't quite get it, here's what I have. Any ideas on how to get this to work?
global string $m341_dupef_SelectedFaces[];
global string $m341_dupef_Child_ObjectName[];
$m341_dupef_SelectedFaces = `ls -fl -sl`;
toggleSelMode;
toggleSelMode;
selectMode -object;
$errorSelectedObjs = `ls -sl`;
//Error if first selected object has child and faces are selected on child object instead of first selected object
//Check if object has child
string $m341_dupef_Child_ObjectName[] = `listRelatives -type transform`;
$size_child_ObjectName = `size $m341_dupef_Child_ObjectName`;
if ($size_child_ObjectName > 0)
     //Counter for the for loop
     int $counter = 0;
     //Loop through each face in the array and if it matches child object name error because it's on the wrong object
     for ($item in $m341_dupef_SelectedFaces)
string $nameMatch = `match $m341_dupef_Child_ObjectName[$counter] $item`;
if ($nameMatch == $m341_dupef_Child_ObjectName[$counter])
     error "Doesn't work if object has children, unparent children first";
$counter = $counter + 1;
Replies (0)
