Mel _ Rename error
Mel _ Rename error
jayantbhatt07
Message 1 of 9
Mel _ Rename error
jayantbhatt07
Hi, guys, I'm working on a script where it adds the suffix to an object. Suppose my object name is Sphere and I run this script the new name is Sphere_High but the problem I'm facing If I run this script again on an object the new object name is Sphere_High_High which I don't want, I know I can figure it out by adding conditions but that is also not working for me or I'm noob. Here is the command _
string $sel[] = `ls -sl`;
int $sSize = size($sel);
string $suffix = "_High";
for($eo in $sel)
rename $eo ($eo + $suffix);
Accepted solutions (3)
Replies (8)
Message 2 of 9
rajasekaransurjen
To reuse the script make it as procedure.
global proc Test()
Your script is working good.
global proc high()
for($eo in $sel)
Message 3 of 9
jayantbhatt07
thank for your reply. I know it is working fine but see the attachments. I hope you will get it.
see the attachment ( * )  In that outliner object name is  pCylinder1_High that is fine.
BUT
When I run this script on more time on the same objects the new name is pCylinder1_High_High. Which I don't want.
My main question is that if High suffix is already there it should not work or add that one more time.
Message 4 of 9
rajasekaransurjen
Ok then try this...
global proc high()
    for($eo in $sel)
    if(endString($eo, 5)!="_High")
Message 5 of 9
jayantbhatt07
Thank you so much for your help.
One more doubt Is it possible to take a screenshot in Maya?  ( I know we can use the snipping tool? )
Message 6 of 9
jayantbhatt07
Hi, same issue when I changed it from high to low it's not working. Like if I run this script multiple times on the same object it is continuously adding the suffix.
global proc Low()
string $suffix = "_Low";
for($eo in $sel)
if(endString($eo, 5)!="_Low")
Message 7 of 9
olarn
How many characters do you think are there in "_Low"
Message 8 of 9
jayantbhatt07
Hi,Thank you so much got your point. It has 4 characters that mean I have to change that no. From 5 to 4.
Message 9 of 9
rajasekaransurjen
yes you got it...
