MEL procedure on file needs to source itself to get global variables?
I know, why MEL... Sadly, Maya LT doesn't let my clients use Python, so that's my torture.
I just discovered this.
I declare several variables in this MEL file.and then have a procedure with the SAME name as the file.
I run the file name, but the globals are not loaded.
Should I call source with the file name inside this procedure to be able to get the globals?
I thought when you run a file it was sourced by default.
haggi_master
Did you declare your variables as global?
global int $val = 123;
global proc myscript()
    global int $val;
    print("Global int " + $val + "\n");
The global declaration in the function body is the most important one.
Yes I did. It's all good. But somehow if I don't run a source on the file it doesn't recognize the variables running the script from a mel file using the name of the file command (so that Maya finds the file with the same name and the procedure inside). I thought maya already sourced the file before finding the procedure inside.
haggi_master
Usually it does if it knows that the script exists. e.g. if you start maya and create a new script, maya does not know anything about the script. In this case you have to do a "rehash" to let maya know that something has changed. But if you start Maya with an exsiting script it should work exactly as you say.
I understand that rehash is only to add files, not to "reload" the files. But well, thanks!
