MEL If command syntax?
peter_baehr97
peter_baehr97
I am trying to use an if command but Maya will keep telling me there is a syntax error. I think I use the wrong symbols around the condition of the if command, but i can't figure out whats the correct one.
The script is supposed to check if the Window "rigWindow" exists, and if the answer is yes i want to close it.
The script that does not work:
if ('window -exists rigWindow')
deleteUI rigWindow;
I tried multiple different things but its frustrating as this seems like  a minor mistake. Can someone tell me what the correct syntax for this command would be? Greatly appreciating any help.
brentmc
You need to enclose the window command in backticks (`) not single quotes. (')
Brent McPherson
Principle Software Developer
peter_baehr97
Thanks for the Reply! Its working now. I also exchanged the normal brackets with {}.
For anyone who has the same problem this is what the correctly working script looks like:
if ( `window -exists rigWindow` )
   deleteUI rigWindow;
