So this was quite challenging, I ended up with a workaround. Instead of removing the carriage return at the end of the text file I always add a carriage return to the end, this way when I use the append command to add text to the file it always has a consistent file to begin with so I can remove my "\n" from my text write proc and keep the file from growing each time the proc is executed. I feel like there's a better way to do this without opening and closing the file so many times, but I couldn't figure it out. Probably won't make sense, but here's the code to prep the file before writing into it.
//Find Maya current version script folder
string $mayaScriptDir = `internalVar -userScriptDir`;
//Create file path
string $filePath = ($mayaScriptDir + "userSetup.mel");
//See if userSetup.mel exists
int $userSetupExists = `file -q -exists $filePath`;
//Define file id
int $fileId;
//Create file if it doesn't exist and write text into it
if ($userSetupExists == 0)
//Open file
$fileId = `fopen ($mayaScriptDir + "userSetup.mel") "a"`;
//Write text into file
fprint $fileId ("\n" + $m341_extraHUD_print_textArray[0]);
//Close file
fclose $fileId;
//If file exists
if ($userSetupExists == 1)
//Strip white space and add carriage return to append works correctly
//Open file
$fileId = `fopen $filePath "r"`;
//Get The First Line
string $nextLine = `fgetline $fileId`;
//Define string array
string $dataArray[];
$dataArray = {""};
while (size($nextLine) > 0)
//Strip whitespace from the beginning and end of line
string $cleanLine = strip($nextLine);
//Add to array
$dataArray[size($dataArray)] = $cleanLine;
//Get next line and continue
//Remove first line from array to fix line counting
stringArrayRemoveAtIndex(0,$dataArray);
fclose $fileId;
//Add carriage return to end of file so append works consistently
//Open file
$fileId = `fopen $filePath "w"`;
//Print array to file
int $counter = 0;
for ($item in $dataArray)
fprint $fileId ($dataArray[$counter] + "\n");
$counter = $counter + 1;
//Close File
fclose $fileId;
