Mel how to remove the carriage return at the end of my text file.
malcolm_341
malcolm_341
Hello, I'm trying to remove an additional carriage return at the end of an external text file, is there a way to do this in Mel?
malcolm_341
So this was quite challenging, I ended up with a workaround. Instead of removing the carriage return at the end of the text file I always add a carriage return to the end, this way when I use the append command to add text to the file it always has a consistent file to begin with so I can remove my "\n" from my text write proc and keep the file from growing each time the proc is executed. I feel like there's a better way to do this without opening and closing the file so many times, but I couldn't figure it out. Probably won't make sense, but here's the code to prep the file before writing into it.
//Find Maya current version script folder
string $mayaScriptDir = `internalVar -userScriptDir`;
//Create file path
string $filePath = ($mayaScriptDir + "userSetup.mel");
//See if userSetup.mel exists
int $userSetupExists = `file -q -exists $filePath`;
//Define file id
int $fileId;
//Create file if it doesn't exist and write text into it
if ($userSetupExists == 0)
	//Open file
	$fileId = `fopen ($mayaScriptDir + "userSetup.mel") "a"`;
	//Write text into file
	fprint $fileId ("\n" + $m341_extraHUD_print_textArray[0]);
	//Close file
	fclose $fileId;
//If file exists
if ($userSetupExists == 1)
	//Strip white space and add carriage return to append works correctly
	//Open file
	$fileId = `fopen $filePath "r"`;
	//Get The First Line
	string $nextLine = `fgetline $fileId`;
	//Define string array
	string $dataArray[];
	$dataArray = {""};
	while (size($nextLine) > 0)
		//Strip whitespace from the beginning and end of line
		string $cleanLine = strip($nextLine);
		//Add to array
		$dataArray[size($dataArray)] = $cleanLine;
		//Get next line and continue
	//Remove first line from array to fix line counting
	stringArrayRemoveAtIndex(0,$dataArray);
	fclose $fileId;
	//Add carriage return to end of file so append works consistently
	//Open file
	$fileId = `fopen $filePath "w"`;
	//Print array to file
	int $counter = 0;
	for ($item in $dataArray)
		fprint $fileId ($dataArray[$counter] + "\n");
		$counter = $counter + 1;
	//Close File
	fclose $fileId;
