Mel, Duplicate object at vertex locations
RickFalck
RickFalck
Mel Noob...
Trying to duplicate a bone at the location of each vertices of a selected object.
Trying to cast vertex selection to an array, and i think that works, but then when trying to match transforms i get 'need to have two objects selected' error.
Was trying to modify an earlier script that works ok when replacing other objects, but i think im missing something with how vertex names are stored.
here is the code
//Duplicate joint0 at Selected vert Locations
if (`objExists joint0`)
    // Cast the vertices of selected into an array
    string $selVerts[] = `polyListComponentConversion -tv -fe`;
    // See if nothing is selected
    if ($selVerts[0] != "")
      // Perform for each selected
        for ( $i=0; $i<size($selVerts); $i++ )
            //Selects and duplicates joint0
            select -r joint0;
            duplicate -n newJoint;
            //Moves duplicate joint to selected pin location
            matchTransform -pos newJoint $selVerts[$i];
			print ("Duplicated successfully. \n");
          }// end of for
      }// // end of if
      else
        string $s ="Error: Something went Wrong! \n";
        print $s;
       }// // end of if objExists
else
print "joint0 object is missing. \n";
I feel like im close but missing something probably obvious.
RickFalck
any ideas on this? is there a way to store all vertex locations in an array?
mspeer
Hi!
There are several errors in this code, so besides the basic idea you are not very close.
Problem 1:
matchTransform does not work with components, this only works with objects.
Problem 2:
polyListComponentConversion only provides one entry OBJECTNAME.vtx[*]
I recommend to test the individual commands before creating the final code.
RickFalck
Thanks yes i figured out matchTransform does not work with components. After that it started to come together.
Probably a cleaner or easier way to do this, but here is what it looks like.
*Updated*
string $MyObj[] = `ls -sl`;
//Creates array of vertex IDs
int $selVerts[] = `polyEvaluate -v $MyObj`;
int $i = 0;
    for($i; $i < $selVerts[0]; $i++)
        select -r joint0;
        //Creates float array that = XYZ of vertexIDs
        float $fVtxPos[] = `xform -q -ws -t ($MyObj[0] + ".vtx["+$i+"]")`;
        print($obj + ".vtx["+$i+"] " + $fVtxPos[0] + " " + $fVtxPos[1] + " " + $fVtxPos[2] + "\n");
        //moves newJoint and renames
        move -a $fVtxPos[0] $fVtxPos[1] $fVtxPos[2] newJoint;
        rename duplicatedJoint;
