Case conversation is below:
Hi Haggi,
What kind of UI response you are getting? Is it model dialogbox or modeless or fprint() statement or any callback? Since you are using similar code as mtoa arnold renderer plugin, is that plugin works well for you? If possible could you please share the sample code?
Best Regards,
Vijaya Prakash
Comments from Haggi,
Okay. Meanwhile I had a look at the code which mtoa uses and could see that they found a workaround for this problem. But I'd prefer to use the tools as they are not workarounds if possible.
And yes, the mtoa-workaround seemt to work.
With the original code as soon as the MComputation starts, the UI is locked. What I want is a way to manipulate the scene during rendering, not to get feedback from somere else.
So if you maybe can confirm that this bug is still existent, I'll use the workaround.
Hi Haggi,
I had a discussion with Engineering team and they confirmed that this bug still exists. So, you can use the workaround that you found it in MtoA Arnold Plugin. We will get back to you once this bug is fixed.
Thanks a lot for your support.
Best Regards,
Vijaya Prakash
