Maya2020Python Can't get the number of mel.eval('uvTkDoGetTexelDensity')
243202504
Message 1 of 10
243202504
I used Maya’s script editor to write the code, and I encountered a problem in it. I want to get the pixel density of my selected part. This function is available in Maya’s UV toolkit. Click the Get button as shown in the figure below. Get a number in the back box, but I don't know how to get this number through code. Including me, I can't get the 512 after the Map Size below.
The code I use is
当我打印它,我得到没有。也许此功能不会返回值,但会将获得的值给 UI 界面后面的框。
4 月 1 日, 吉马亚 · 伊金 · 吉亚 · 吉亚 · 吉特 · 吉夫 · 特夫特 · 特瓦特 · 特格特 · 吉夫(三)次次次的"大号"
我使用的代码是
打印打印可能这个功能没有返回值,而是把得到的值给了UI界面后面的方框里。
Replies (9)
Message 2 of 10
243202504
There are errors in the Chinese part above, just read English.
Message 3 of 10
243202504
When I print its value, I get None. Maybe this function will not return a return value, but will give the obtained value to the UI box later. I need your help and tell me how to get the average pixel density calculated in the box below.
Message 4 of 10
zewt
uvTkDoGetTexelDensity is a callback for updating a UI field, it doesn't return a value.  It just takes the texture size and calls texGetTexelDensity:
map_size = cmds.optionVar('polyUVTexelDensityMapSize', q=True)
density = mel.eval('texGetTexelDensity(%i)' % map_size)
map_size is the texture size set in the options box.  The polyUVTexelDensityMapSize optionVar won't exist if the user hasn't used that options box before.  texGetTexelDensity will also raise an error if there's no object selected to query density for.
Message 5 of 10
243202504
Thanks for ur reply!
"map_size is the texture size set in the options box. The polyUVTexelDensityMapSize optionVar won't exist if the user hasn't used that options box before."
I don't know how to set texture size, I give a number in 'Map Size:' box (512). script editor raise 'uvTkTexelDensityChangeCB', and then I run
import maya.cmds as cmds
print map_size
it raise
# Error: Object polyUVTexelDensityMapSize is invalid
# Traceback (most recent call last):
#   File "<maya console>", line 3, in <module>
# TypeError: Object polyUVTexelDensityMapSize is invalid #
Message 6 of 10
243202504
ok i found a way ,
map_size = cmds.optionVar(q='polyUVTexelDensityMapSize')
and then i got print 512.
Message 7 of 10
zewt
FYI, that's just the last-used setting in the options box (and it won't exist if that options box has never been used).
Message 8 of 10
243202504
yeah,and i create a value,then it will be created.
i use it at my code first line like this
# coding=utf-8
from maya import mel
from functools import wraps
and then it will be created.
Message 9 of 10
243202504
btw,i have a new quesion now,,, i can query the value of map_size,but i found,optionVar is undoable, queryable, and NOT editable. so if i want change the valuse of ui box, set size as 512 or 1024 ,how can i do ,what commnd should i use? ty!
Message 10 of 10
243202504
texCalculateTexelDensity
This line of code takes too long. Is there any other way? If I get the vertices of the face, the UV ratio and the texture size to calculate the accuracy, or if I don’t need to call mel, but directly use python to speed it up. This Lines of code take up more than 90% of the time consumed by my entire tool. I want to optimize it.
