Maya Lib Mismatch
Maya Lib Mismatch
Message 1 of 1
Maya Lib Mismatch
Hey,
I've been developing some tools that use the maya sdk to parse files. While moving these tools from the 2008 sdk to the 2011 sdk I know get a popup message when it uses maya.
The message states:
There appears to be a mismatch between MayaSDK and the DLL's that were loaded. THIS APP MAY NOT WORK PROPERLY. Make sure that the SDK version of Maya is installed and the first one to appear in your PATH environment variable.
SDK version = 1.0.0 DLL version = 2011
I believe I have things setup properly but I was wondering if there is a switch in the registry or some other variable that needs to be adjusted to get this to work properly.
Sam
Replies (0)
