Maya Gets Crashed with Status 139
When I am Trying to Fire render using Terminal Maya gets Crashed Everytime.To stop this I Reinstall Maya and then it works fine but this Error comes after some time.
Error :
Starting "/maya2017/maya"
Stack trace:
glGetString
Fatal Error. Attempting to save in /tmp/rendersg.20180508.1059.ma
Segmentation fault
// Maya exited with status 139
I am Using Maya 2017
Can anyone tell me what is the meaning of this error and how to solve it ?
warnold2
Error code 139 is the exit code provided by the system from receiving a signal 11, a segmentation fault
https://www.centos.org/docs/5/html/5.2/Installation_Guide/ch14s01s01.html
The return code is: 128 + 11 = 139
the stack trace starting with “glGetString” implies there is no current OpenGL context active.
in batch mode there is no GUI initialized which is where OpenGL is initialized
there would normally be a longer stack trace to see where the code path started. If it’s a plug-in that is expecting to have OpenGL access
is there a graphic card and drivers installed on the machine
if so what are they, versions
Wayne Arnold
Developer
