Maya crashed by calling <MItMeshVertex>.getNormal().
Message 1 of 8
I was trying to get normal from the vertices that I select. but this code crashes maya.
I'm using maya 2019 in linux. if I use vert_itr.getNormals instead of vert_itr.getNormal, maya does not crash and returns proper vectors. but it returns the normals  of the current vertex for all faces.
I want to use getNormal  to get average normal for the vertex. but maya crashes with the function.
import maya.api.OpenMaya as OM2
sel = OM2.MGlobal.getActiveSelectionList()
dag, component = sel.getComponent(0)
if not component.isNull():
    # There were components selected
    vert_itr = OM2.MItMeshVertex(dag, component)
    while not vert_itr.isDone():
        rayDirection = vert_itr.getNormal(OM2.MSpace.kWorld)
        vert_itr.next()
Replies (7)
Message 2 of 8
stuzzz
Do you have the same problem with MItMeshVertex::getNormals()?
It would be way faster and better (if that avoid crashes).
Message 3 of 8
thanks for reply @stuzzz
but if I use getNormals, I need to calculate average Normal again.
this worked fine in api 1.0. and I was translating this from api 1.0 to api 2.0. and I'm having issue with this.
so I'm wondering if I used this function wrong or if there is another issue.
Message 4 of 8
I just tested this code in maya 2020 on window machine.
and maya crashes as well.
anyone can take a look at this?
Message 5 of 8
stuzzz
Sorry I haven't read carefuly (sic!)
If you do something like this, it should work (it does on Maya2018).
I guess that something got wrong with the MSelectionList::getComponent()
you should use the MSelectionList::getDagPath instead
The component is stored in the MObject obj  which can be then passed to the MItMeshVertex constructor
sel = MSelectionList()
MGlobal.getActiveSelectionList(sel)
src=MDagPath();obj=MObject()
sel.getDagPath(0,src, obj)
it = MItMeshVertex(src, obj)
while not it.isDone():
	norm = MVector()
	it.getNormal(norm, MSpace.kWorld)
	it.next()
Message 6 of 8
I have similar code in api 1.0 like you and it works fine, but if I translate it into api 2.0 and does not work.
Message 7 of 8
stuzzz
it seems like you have your answer...
Message 8 of 8
michael.trainor
Just hit this myself. This was my solution. I use the indices with the index array I get from getTriangles().
indicies = list(mesh_polygon_iter.getVertices())
normals = list(mesh_polygon_iter.getNormals())
packed_normals = {v: list(n) for v, n in zip(indicies, normals)}
Good luck out there!
