Maya batch will trigger Autodesk Crash Report window to pause the running process
jiajun.coding
jiajun.coding
Hi experts,
I will run a maya batch exe to input thousands of maya files to validate assets data. But some maya files will crash to pause batch process so I have to close Autodesk Error Report window manually.  How to disable this feature in the MayaBatch?
Edit:
Not every time Error Report Window will pause process.
jiajun.coding
Tried MAYA_DEBUG_ENABLE_CRASH_REPORTING=0 in environment variables or maya.env. Both not work..
jiajun.coding
Another thing I want to implement is to query these crashed files which caused Error Report dialog so that I can plan to fix these files to continue.
