maya 2023 script editor
harish.s2020a
Observer Observer
harish.s2020a
Observer
Observer
# Error: invalid syntax
# # Traceback (most recent call last):
# # File "<maya console>", line 1, in <module>
# # File "C:\Users/ADMIN/Documents/maya/scripts\JUM\scripts\braid.py", line 152
# # print poly
# # SyntaxError: Missing parentheses in call to 'print'. Did you mean print(poly)?
i have no exprience in codes, how to solve this?
ryan.lloyd6764X
If you open up "C:\Users/ADMIN/Documents/maya/scripts\JUM\scripts\braid.py" in a text editor, you will need to place parentheses "(" ")" around the variable placed after the print function on line 152 of the code like it shows in the suggestion "print(poly)".
The script you are trying to use was probably scripted for python2 where python 3+ requires parentheses to be used with the print function.
harish.s2020a
Observer
Observer
thanks for solution that error has been resolved, but got more errors
# # File "C:\Users/ADMIN/Documents/maya/scripts\JUM\scripts\braid.py", line 7, in <module>
# # from JUM.core.loadUIFile import get_maya_window, load_ui_type
# # File "C:\Users/ADMIN/Documents/maya/scripts\JUM\core\loadUIFile.py", line 25
# # (exec) pyc in frame
# # SyntaxError: invalid syntax
