Message 1 of 1
Maya (2023) crashes when tuple supplied as flag to command in python api 2
import sys
import maya.api.OpenMaya as om
def maya_useNewAPI():
The presence of this function tells Maya that the plugin produces, and
expects to be passed, objects created using the Maya Python API 2.0.
pass
kShortFlagName = '-tf'
kLongFlagName = '-myTupleFlag'
class MyCommandWithFlagClass(om.MPxCommand):
kPluginCmdName = 'myCommandWithFlag'
def __init__(self):
super(MyCommandWithFlagClass, self).__init__()
def doIt(self, args):
self.parseArguments(args)
def parseArguments(self, args):
argData = om.MArgParser(self.syntax(), args)
if argData.isFlagSet(kShortFlagName):
flagParam0 = argData.flagArgumentInt(kShortFlagName, 0)
flagParam1 = argData.flagArgumentInt(kShortFlagName, 1)
flagParam2 = argData.flagArgumentInt(kShortFlagName, 2)
print(kLongFlagName + '[0]: ' + str(flagParam0))
print(kLongFlagName + '[1]: ' + str(flagParam1))
print(kLongFlagName + '[2]: ' + str(flagParam2))
@staticmethod
def cmdCreator():
return MyCommandWithFlagClass()
@staticmethod
def syntaxCreator():
syntax = om.MSyntax()
syntax.addFlag(kShortFlagName, kLongFlagName, om.MSyntax.kDouble, om.MSyntax.kDouble, om.MSyntax.kDouble)
return syntax
# Initialize the plug-in
def initializePlugin(plugin):
pluginFn = om.MFnPlugin(plugin)
try:
pluginFn.registerCommand(
MyCommandWithFlagClass.kPluginCmdName, MyCommandWithFlagClass.cmdCreator, MyCommandWithFlagClass.syntaxCreator
except:
sys.stderr.write(
"Failed to register command: %s\n" % MyCommandWithFlagClass.kPluginCmdName
# Uninitialize the plug-in
def uninitializePlugin(plugin):
try:
pluginFn.deregisterCommand(MyCommandWithFlagClass.kPluginCmdName)
except:
sys.stderr.write(
"Failed to unregister command: %s\n" % MyCommandWithFlagClass.kPluginCmdName
I took line 46 (and the rest of the contents of the syntaxCreator method) directly from the documentation so I'm not sure why it's crashing. Any help would be greatly appreciated!
-Harry
