Maya (2023) crashes when tuple supplied as flag to command in python api 2
houghton07
Message 1 of 1
houghton07
I found this documentation for supplying a tuple as a flag to a custom command in api 1 and I'm tried conver...
import sys
import maya.api.OpenMaya as om
def maya_useNewAPI():
    The presence of this function tells Maya that the plugin produces, and
    expects to be passed, objects created using the Maya Python API 2.0.
    pass
kShortFlagName = '-tf'
kLongFlagName = '-myTupleFlag'
class MyCommandWithFlagClass(om.MPxCommand):
    kPluginCmdName = 'myCommandWithFlag'
    def __init__(self):
        super(MyCommandWithFlagClass, self).__init__()
    def doIt(self, args):
        self.parseArguments(args)
    def parseArguments(self, args):
        argData = om.MArgParser(self.syntax(), args)
        if argData.isFlagSet(kShortFlagName):
            flagParam0 = argData.flagArgumentInt(kShortFlagName, 0)
            flagParam1 = argData.flagArgumentInt(kShortFlagName, 1)
            flagParam2 = argData.flagArgumentInt(kShortFlagName, 2)
            print(kLongFlagName + '[0]: ' + str(flagParam0))
            print(kLongFlagName + '[1]: ' + str(flagParam1))
            print(kLongFlagName + '[2]: ' + str(flagParam2))
    @staticmethod
    def cmdCreator():
        return MyCommandWithFlagClass()
    @staticmethod
    def syntaxCreator():
        syntax = om.MSyntax()
        syntax.addFlag(kShortFlagName, kLongFlagName, om.MSyntax.kDouble, om.MSyntax.kDouble, om.MSyntax.kDouble)
        return syntax
# Initialize the plug-in
def initializePlugin(plugin):
    pluginFn = om.MFnPlugin(plugin)
    try:
        pluginFn.registerCommand(
            MyCommandWithFlagClass.kPluginCmdName, MyCommandWithFlagClass.cmdCreator, MyCommandWithFlagClass.syntaxCreator
    except:
        sys.stderr.write(
            "Failed to register command: %s\n" % MyCommandWithFlagClass.kPluginCmdName
# Uninitialize the plug-in
def uninitializePlugin(plugin):
    try:
        pluginFn.deregisterCommand(MyCommandWithFlagClass.kPluginCmdName)
    except:
        sys.stderr.write(
            "Failed to unregister command: %s\n" % MyCommandWithFlagClass.kPluginCmdName
 I took line 46 (and the rest of the contents of the syntaxCreator method) directly from the documentation so I'm not sure why it's crashing.  Any help would be greatly appreciated!
-Harry
Replies (0)
