Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Maya 2022 crashes when accessing MIntArray with negative indices
e_honda
e_honda
Hi there,
I was testing the new Maya 2022 in its Python 3 mode and encountered some problem.
I realized that some scripts those worked in earlier version just crashes Maya 2022.
I did a quick research about that and extracted a simple code that can reproduce the error.
from maya.api import OpenMaya
# create an OpenMaya.MIntArray object
temp_list = OpenMaya.MIntArray([0,1])
# accessing array's member using negative index crashes Maya 2022 with fatal error
print(temp_list[-1])
I'm running Maya 2022.0 in Windows 10.
As a workaround, I'm using a little function to convert negative indices to positive ones.
Is it a problem that occurs just in my environment?
Best Regards,
Honda
e_honda
Just a quick update.
Other OpenMaya's array types also crashes Maya 2022.
It seems that launching Maya 2022 in Python 2 mode avoids the problem.
Maybe there is some problem in the Python 3 version of the Python API 2.0?
temp_list = OpenMaya.MFloatArray([0.0, 1.0])
temp_list = OpenMaya.MPointArray([OpenMaya.MPoint(), OpenMaya.MPoint()])
WindXu
Thanks for reporting this issue. I can reproduce it with Maya 2022 in Python 3 mode, but not in Python 2 mode. I have logged a bug internally. We will fix it as soon as possible.
Thanks again
e_honda
Hi WindXu,
Hope the bug would be fixed in future updates.
I checked that the OpenMaya.XXXXArray has other problem too, so I'll share here in this thread.
# should raise an IndexError, but returns the memory pointer's value?
print(temp_list[50])
For now, I will use a simple function to avoid the error. Maybe not the best solution, but something like below:
def get_item_at_index(omarray, index):
        function made just to avoid problems when accessing Maya2022's OpenMaya.XXXXXXArray items.
    len_array = len(omarray)
    index = len_array + index if index < 0 else index
    if index < 0:
        raise IndexError('list index out of range')
    elif index >= len_array:
    return omarray[index]
print(get_item_at_index(temp_list, -1)
Thanks for your attention!
Best Regards,
Honda
WindXu
Yes, I noticed the issue with out of range index too when I did the test yesterday. I also logged it in the same bug.
negow
Thanks for this, I have been experiencing this as well!
