Maya 2022 and sys.__stdout__.write
negow
negow
Hi all,
I'm missing the ability to print to the Output Window from Maya 2022, like I could in 2020 and below.
My primary use and what I miss the most is "clearing" the output window, when I'm particulatly keen on what message comes next in a series of similar messages.
import sys
for emptyline in range(50):
    sys.__stdout__.write("\n")
For completenss, __stdout__ is Python's original sys.stdout, used in cases where someone overwrites it like Maya does to instead print to the Script Editor.
sys.stdout
# Result: <maya.Output object at 0x0000020B4AF819F0> #
Is there another way of writing to the Output Window?
e_honda
Using Maya 2022 in Python 3 mode, the only way I could write to Output Window was using a MEL function.
There should be a better way to solve the problem, but I could not find it.
from maya import mel
mel.eval('trace "write directly to Output Window\n"')
Hope it helps.
negow
Thanks, this helps!
WindXu
@negow @e_honda This is actually a Python 3 buffering issue.
You can workaround it by calling sys.__stdout__.flush() at the end of your script.
The following script should work for you.
import sys
negow
Thanks @WindXu that does make sense!
