Building PyQt5 for Maya 2022
I'm following these steps:
https://around-the-corner.typepad.com/adn/2021/03/how-to-build-pyqt5-for-maya-2022.html
I believe I've done everything correctly but I'm stuck on the last step. I open a x64 Native Tools cmd window as admin. Navigate to where I unzipped 'PyQt5-5.15.4' then run the sip-install command, accept the terms, but then it just loops repeating these two permission errors:
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "c:\users\main\appdata\local\programs\python\python39\lib\tempfile.py", line 801, in onerror
_os.unlink(path)
PermissionError: [WinError 5] Access is denied: 'C:\\Users\\MAIN\\AppData\\Local\\Temp\\tmpj9671uxl'
File "c:\users\main\appdata\local\programs\python\python39\lib\shutil.py", line 620, in _rmtree_unsafe
os.rmdir(path)
PermissionError: [WinError 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\MAIN\\AppData\\Local\\Temp\\tmpj9671uxl'
Tried restarting my computer and then double checking through all the steps but no luck. Is this a problem with my system or have I just done one of the steps wrong?
