Maya 2018 and Xcode 9.2
chaneyx
chaneyx
Does Xcode 9.2 work with Maya 2018? The docs say to use Xcode 7.3.1 but I would like to use the boost libraries but I cannot install it with Xcode 7.3.1.
brew install boost
Error: Your Xcode (7.3.1) is too outdated.
Please update to Xcode 9.2 (or delete it).
Xcode can be updated from the App Store.
Thank you
ikolev
It does, starting from Maya 2016.5.
ikolev
Actually I wasn't very precise. The Clang ABI doesn't seem to have changed so it is OK to compile for any Maya with any Xcode / Clang version.
What did change in 2016.5 was the standard C++ library that Maya gets compiled with, and since the Maya API uses the STL in a few places, plugins are forced to either compile with the same STL or make some efforts to isolate the STL-dependent code in a separately compiled dynamic library.
So the correct answer is, whatever Xcode/Clang you're developing your plugin with, be careful to compile with the correct STL: for Maya 2016 or earlier it was GNU libstdcpp, for 2016.5 or later it is Clang's libcpp (which is the default).
