Announcements
Maya 2017 Update 5 Playblast Crash
Message 1 of 1
I'm developing a maya plugin using pyqt that allow animators to automatically playblast their scene using preset that already setup.
sometimes when the animator click my pyqt button on playblast UI that i created it make maya crashed. this thing never happened when we use maya 2015 SP6.
here is my Maya Crash Log.
it's said something wrong with QTWidget.dll
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000008
Fault address:  1ED76CB6 in C:\Program Files\Autodesk\Maya2017\bin\Qt5Gui.dll
0001:00065CB6 Logical offset (see .map file for location)
Call stack:
(11) section:offset 0001:00065CB6 Address: 0x1ED76CB6 Frame: 0x44FF8A60
	Module:  C:\Program Files\Autodesk\Maya2017\bin\Qt5Gui.dll (-exported-)
	Decl: public: bool QOpenGLContext::isOpenGLES(void)
	Source:  (0)
(12) section:offset 0001:0000D61F Address: 0x57D2E61F Frame: 0x44FF8AB0
	Module:  C:\Program Files\Autodesk\Maya2017\bin\Qt5OpenGL.dll (-exported-)
	Location: QGLFramebufferObject::QGLFramebufferObject + 0x6F bytes
	Decl: public: QGLFramebufferObject::QGLFramebufferObject(class QSize const & ptr64,enum QGLFramebufferObject::Attachment,unsigned int,unsigned int)
	Source:  (0)
(13) section:offset 0001:0002A553 Address: 0x45CBB553 Frame: 0x44FF8B10
	Module:  C:\Program Files\Autodesk\Maya2017\bin\3dGraphics.dll (-exported-)
	Decl: public: bool QmayaGLRenderTarget::create(class QSize const & ptr64,class QGLFormat const * ptr64,class QGLWidget * ptr64)
	Source:  (0)
(14) section:offset 0001:00027D89 Address: 0x45CB8D89 Frame: 0x44FF8B50
	Decl: public: class QmayaGLRenderTarget * ptr64 Q3dPort::createOffscreenTarget(class QSize const & ptr64,class QGLFormat const * ptr64)
	Source:  (0)
(15) section:offset 0001:00081949 Address: 0x074B2949 Frame: 0x44FF8BE0
	Module:  C:\Program Files\Autodesk\Maya2017\bin\AnimUISlice.dll (-exported-)
	Location: TanimationEditorCmd::setAnimEditor + 0x14249 bytes
	Decl: public: void TanimationEditorCmd::setAnimEditor(class TanimEditor * ptr64)
	Source:  (0)
(16) section:offset 0001:0007F7D4 Address: 0x074B07D4 Frame: 0x44FF8C40
	Location: TanimationEditorCmd::setAnimEditor + 0x120D4 bytes
	Source:  (0)
(17) section:offset 0001:0007F49D Address: 0x074B049D Frame: 0x44FF8F20
	Location: TanimationEditorCmd::setAnimEditor + 0x11D9D bytes
	Source:  (0)
(18) section:offset 0001:0007D0CB Address: 0x074AE0CB Frame: 0x44FF9080
	Location: TanimationEditorCmd::setAnimEditor + 0xF9CB bytes
	Source:  (0)
(19) section:offset 0001:0007C75A Address: 0x074AD75A Frame: 0x44FF90E0
	Location: TanimationEditorCmd::setAnimEditor + 0xF05A bytes
	Source:  (0)
(20) section:offset 0001:00079725 Address: 0x074AA725 Frame: 0x44FF96E0
	Location: TanimationEditorCmd::setAnimEditor + 0xC025 bytes
	Source:  (0)
(21) section:offset 0001:00015B11 Address: 0x35B56B11 Frame: 0x44FF9750
	Module:  C:\Program Files\Autodesk\Maya2017\bin\CommandEngine.dll (-exported-)
	Decl: public: virtual bool TmetaCommand::doCommand(class TargList & ptr64)
	Source:  (0)
(22) section:offset 0001:000705D5 Address: 0x35BB15D5 Frame: 0x44FF9840
	Location: TpythonInterpreter::dispatchMayaCommand + 0x215 bytes
	Decl: public: static struct _object * ptr64 TpythonInterpreter::dispatchMayaCommand(class TmetaCommand & ptr64,struct _object * ptr64,struct _object * ptr64)
	Source:  (0)
(23) section:offset 0001:000F1646 Address: 0x57E72646 Frame: 0x44FF9870
	Module:  C:\Program Files\Autodesk\Maya2017\bin\python27.dll (-exported-)
	Source:  (0)
(24) section:offset 0001:0015599A Address: 0x57ED699A Frame: 0x44FF98C0
	Source:  (0)
(25) section:offset 0001:00155421 Address: 0x57ED6421 Frame: 0x44FF9920
	Source:  (0)
(26) section:offset 0001:00152B62 Address: 0x57ED3B62 Frame: 0x44FF9A30
	Source:  (0)
(27) section:offset 0001:00153F21 Address: 0x57ED4F21 Frame: 0x44FF9AE0
	Source:  (0)
(28) section:offset 0001:001555B8 Address: 0x57ED65B8 Frame: 0x44FF9B50
	Source:  (0)
(29) section:offset 0001:00155414 Address: 0x57ED6414 Frame: 0x44FF9BB0
	Source:  (0)
(30) section:offset 0001:00152B62 Address: 0x57ED3B62 Frame: 0x44FF9CC0
	Source:  (0)
(31) section:offset 0001:00153F21 Address: 0x57ED4F21 Frame: 0x44FF9D70
	Source:  (0)
(32) section:offset 0001:000DFB88 Address: 0x57E60B88 Frame: 0x44FF9DF0
	Source:  (0)
(33) section:offset 0001:000AC9D6 Address: 0x57E2D9D6 Frame: 0x44FF9E20
	Source:  (0)
(34) section:offset 0001:000C1124 Address: 0x57E42124 Frame: 0x44FFA0A0
	Source:  (0)
(35) section:offset 0001:000AC9D6 Address: 0x57E2D9D6 Frame: 0x44FFA0D0
	Source:  (0)
(36) section:offset 0001:00154F8E Address: 0x57ED5F8E Frame: 0x44FFA100
	Source:  (0)
(37) section:offset 0001:0000606B Address: 0x334F706B Frame: 0x44FFA180
	Module:  C:\Program Files\Autodesk\Maya2017\bin\pyside2.dll (-exported-)
	Location: PySide::SignalManager::callPythonMetaMethod + 0x15B bytes
	Decl: public: static int PySide::SignalManager::callPythonMetaMethod(class QMetaMethod const & ptr64,void * ptr64 * ptr64,struct _object * ptr64,bool)
	Source:  (0)
(38) section:offset 0001:00005ECB Address: 0x334F6ECB Frame: 0x44FFA1D0
	Location: PySide::SignalManager::addGlobalSlot + 0xEB bytes
	Decl: public: void PySide::SignalManager::addGlobalSlot(char const * ptr64,struct _object * ptr64)
	Source:  (0)
(39) section:offset 0001:00006B9E Address: 0x334F7B9E Frame: 0x44FFA280
	Location: PySide::SignalManager::qt_metacall + 0x1CE bytes
	Decl: public: static int PySide::SignalManager::qt_metacall(class QObject * ptr64,enum QMetaObject::Call,int,void * ptr64 * ptr64)
	Source:  (0)
(40) section:offset 0001:0007A07A Address: 0x06BDB07A Frame: 0x44FFA2B0
	Module:  C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\PySide2\QtWidgets.pyd (-exported-)
	Source:  (0)
(41) section:offset 0001:001CB79F Address: 0x587FC79F Frame: 0x44FFA3C0
	Module:  C:\Program Files\Autodesk\Maya2017\bin\Qt5Core.dll (-exported-)
	Decl: public: static void QMetaObject::activate(class QObject * ptr64,int,int,void * ptr64 * ptr64)
	Source:  (0)
(42) section:offset 0001:000F445C Address: 0x581C545C Frame: 0x44FFA410
	Module:  C:\Program Files\Autodesk\Maya2017\bin\Qt5Widgets.dll (-exported-)
	Decl: public: void QAbstractButton::clicked(bool)
	Source:  (0)
(43) section:offset 0001:000F4383 Address: 0x581C5383 Frame: 0x44FFA450
	Decl: public: void QAbstractButton::click(void)
	Source:  (0)
(44) section:offset 0001:000F51C8 Address: 0x581C61C8 Frame: 0x44FFA480
	Location: QAbstractButton::mouseReleaseEvent + 0x88 bytes
	Decl: protected: virtual void QAbstractButton::mouseReleaseEvent(class QMouseEvent * ptr64)
	Source:  (0)
(45) section:offset 0001:001E71AF Address: 0x06D481AF Frame: 0x44FFA4D0
	Source:  (0)
(46) section:offset 0001:00040C12 Address: 0x58111C12 Frame: 0x44FFA6A0
	Decl: protected: virtual bool QWidget::event(class QEvent * ptr64)
	Source:  (0)
(47) section:offset 0001:001E3162 Address: 0x06D44162 Frame: 0x44FFA700
	Source:  (0)
(48) section:offset 0001:00016CB2 Address: 0x580E7CB2 Frame: 0x44FFA730
	Location: QApplicationPrivate::notify_helper + 0x112 bytes
	Decl: public: bool QApplicationPrivate::notify_helper(class QObject * ptr64,class QEvent * ptr64)
	Source:  (0)
(49) section:offset 0001:0001491E Address: 0x580E591E Frame: 0x44FFAE50
	Decl: public: virtual bool QApplication::notify(class QObject * ptr64,class QEvent * ptr64)
	Source:  (0)
(50) section:offset 0001:0000EEB0 Address: 0x2B18FEB0 Frame: 0x44FFAF20
	Module:  C:\Program Files\Autodesk\Maya2017\bin\ExtensionLayer.dll (-exported-)
	Location: TwindowManager::windowPreferencesAreEnabled + 0x2A0 bytes
	Decl: public: bool TwindowManager::windowPreferencesAreEnabled(void)
	Source:  (0)
(51) section:offset 0001:001AB857 Address: 0x587DC857 Frame: 0x44FFAF80
	Location: QCoreApplication::notifyInternal2 + 0xA7 bytes
	Decl: private: static bool QCoreApplication::notifyInternal2(class QObject * ptr64,class QEvent * ptr64)
	Source:  (0)
(52) section:offset 0001:00018092 Address: 0x580E9092 Frame: 0x44FFB090
	Location: QApplicationPrivate::sendMouseEvent + 0x372 bytes
	Decl: public: static bool QApplicationPrivate::sendMouseEvent(class QWidget * ptr64,class QMouseEvent * ptr64,class QWidget * ptr64,class QWidget * ptr64,class QWidget * ptr64 * ptr64,class QPointer<class QWidget> & ptr64,bool)
	Source:  (0)
(53) section:offset 0001:00069C74 Address: 0x5813AC74 Frame: 0x44FFB220
	Decl: public: QSizePolicy::QSizePolicy(void)
	Source:  (0)
(54) section:offset 0001:00067B24 Address: 0x58138B24 Frame: 0x44FFB290
	Source:  (0)
(55) section:offset 0001:00016CB2 Address: 0x580E7CB2 Frame: 0x44FFB2C0
	Source:  (0)
(56) section:offset 0001:00015C19 Address: 0x580E6C19 Frame: 0x44FFB9E0
	Source:  (0)
(57) section:offset 0001:0000EEB0 Address: 0x2B18FEB0 Frame: 0x44FFBAB0
	Source:  (0)
(58) section:offset 0001:001AB857 Address: 0x587DC857 Frame: 0x44FFBB10
	Source:  (0)
(59) section:offset 0001:00030716 Address: 0x1ED41716 Frame: 0x44FFBFA0
	Location: QGuiApplicationPrivate::processMouseEvent + 0x766 bytes
	Decl: public: static void QGuiApplicationPrivate::processMouseEvent(class QWindowSystemInterfacePrivate::MouseEvent * ptr64)
	Source:  (0)
(60) section:offset 0001:00032D00 Address: 0x1ED43D00 Frame: 0x44FFBFF0
	Location: QGuiApplicationPrivate::processWindowSystemEvent + 0x130 bytes
	Decl: public: static void QGuiApplicationPrivate::processWindowSystemEvent(class QWindowSystemInterfacePrivate::WindowSystemEvent * ptr64)
	Source:  (0)
(61) section:offset 0001:00016C2C Address: 0x1ED27C2C Frame: 0x44FFC030
	Location: QWindowSystemInterface::sendWindowSystemEvents + 0x13C bytes
	Decl: public: static bool QWindowSystemInterface::sendWindowSystemEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
	Source:  (0)
(62) section:offset 0001:001F22EB Address: 0x588232EB Frame: 0x44FFC120
	Location: QEventDispatcherWin32::processEvents + 0xE1B bytes
	Decl: public: virtual bool QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>)
	Source:  (0)
(63) section:offset 0001:00015D41 Address: 0x5AD66D41 Frame: 0x44FFC2B0
	Module:  C:\WINDOWS\System32\USER32.dll (-exported-)
	Source:  (0)
(64) section:offset 0001:00015713 Address: 0x5AD66713 Frame: 0x44FFC340
	Source:  (0)
(65) section:offset 0001:001F1A56 Address: 0x58822A56 Frame: 0x44FFF6A0
	Location: QEventDispatcherWin32::processEvents + 0x586 bytes
	Source:  (0)
(66) section:offset 0001:00058599 Address: 0x088E9599 Frame: 0x44FFF6D0
	Module:  C:\Program Files\Autodesk\Maya2017\qt-plugins\platforms\qwindows.dll (-exported-)
	Source:  (0)
(67) section:offset 0001:001A85C1 Address: 0x587D95C1 Frame: 0x44FFF750
	Decl: public: int QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>)
	Source:  (0)
(68) section:offset 0001:001AA65D Address: 0x587DB65D Frame: 0x44FFF7C0
	Decl: public: static int QCoreApplication::exec(void)
	Source:  (0)
(69) section:offset 0001:00009B1A Address: 0x2B18AB1A Frame: 0x44FFF8C0
	Decl: public: void Tapplication::start(void)
	Source:  (0)
(70) section:offset 0001:000021F3 Address: 0xA61931F3 Frame: 0x44FFFAF0
	Module:  C:\Program Files\Autodesk\Maya2017\bin\maya.exe (-exported-)
	Source:  (0)
(71) section:offset 0001:00024B75 Address: 0xA61B5B75 Frame: 0x44FFFB80
	Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x146F5 bytes
	Decl: public: class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > & ptr64 TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator=(class TiteratorWrapperBidir<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> > const & ptr64)
	Source:  (0)
(72) section:offset 0001:00021E98 Address: 0xA61B2E98 Frame: 0x44FFFBC0
	Location: TiteratorWrapperBidir<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator= + 0x11A18 bytes
	Source:  (0)
(73) section:offset 0001:00012034 Address: 0x59693034 Frame: 0x44FFFBF0
	Module:  C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
	Source:  (0)
(74) section:offset 0001:00072691 Address: 0x5B1C3691 Frame: 0x44FFFC40
	Module:  C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
	Source:  (0)
End of stack
//crash log file name = C:\Users\BUNNY-22\AppData\Local\Temp\MayaCrashLog190308.2004.log
//version     = 17.5.3051.0
//cut            = Tue 10/31/2017, 201710312136
//current scene = unDisclosed
//command history (most recent last):
Replies (0)
