Announcements
can only concatenate list (not "str") to list -- PROBLEM
danielblaze
danielblaze
Hi, i'm trying to mirror the channel box attributes of my left joint chain from left to right.
However i'm getting an error with list concatenation!!
Image and code attached below
Can someone help me please?
Daniel
______________________________
import maya.cmds as cmds
sel = cmd.ls(sl=True, dag=True)
leftSel = sel[:len(sel)/2]
rightSel = sel[len(sel)/2:]
cbAttr = cmd.listAttr(leftSel, k=1)
for i in cbAttr:
L_objVal = cmds.getAttr(leftSel + '.' + i)
if i == 'translateX':
cmds.setAttr(rightSel + '.' + i, L_objVal*-1)
if i == 'translateY':
cmds.setAttr(rightSel + '.' + i, L_objVal)
if i == 'translateZ':
if i == 'rotateX':
if i == 'rotateY':
if i == 'rotateZ':
if i == 'scaleX':
if i == 'scaleY':
if i == 'scaleZ':
lanh.hong
Hi danielblaze,
The reason you're getting that error is because leftSel and rightSel are lists while '.' and i  are strings. So concatenating a list with strings does not work in Python. You'd have to loop through the elements in leftSel/rightSel lists if you want to concat with the strings.
Lanh
Lanh Hong
Developer Technical Services
Autodesk Developer Network
