Maya 2017 Script Error
Hello Maya Users
I keep getting the following error message every time Maya autosaves and when I click on any area in the GUI:
// Error: file: G:/Autodesk/Maya2017/scripts/others/drInit.mel line 1961: Object '' not found. //
I looked through the script and I cannot figure out what it is not finding.  Any thoughts on this one?
Okay I was able to answer my own post finally by searching in the Maya LT forum.  Turns out others have had this problem and an Autodesk employee Viviane Rochon was able to answer the issue and provide a new script file that solved the issue.  Here is the link to that post:
http://forums.autodesk.com/t5/maya-lt-general/error-code-at-startup/td-p/6491312
I replaced my old drInit MEL file with the new one and Maya 2017 has been working just fine.
Thank you Viviane.
Irish_diamond
Community Visitor
Community Visitor
Windows>Modeling Editors>Modeling Toolkit;
open this windows,let it appear on the right side of the interface..
 i get this // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290 if i load mmd4 plugin,can you help me
sorry my english
Thank you Viviane.
