Maya 2017 : Python open file API
I use to make a tool to bake animations keys into a particular readable format for another device.
Problem :
I've wrote a part which is parsing a .CSV file in order to load a configuration file.
I've been using this :
with open('C:/QUARANTINES/config_tmp.csv','wb') as csvfile:
# specific delimiter
reader = csv.reader(csvfile,delimiter=',',quotechar='|')
for row in reader :
# each row consists parameters delimited by ','
//doSomething forEach row
But it's not working anymore.
I'm digging into stackOverflow at the moment, to see if there's anything new, but I haven't found anything relevant yet...
Does anybody have a clue ? I'd appreciate 🙂
EDIT : To be accurate ; I precede this by import csv. I've been using this https://docs.python.org/2/library/csv.html?highlight=reader#csv.reader
Hi Arthur
It looks like you are trying to read a csv file, but you have used a write operation on your call to open. Change this line
to this:
with open('C:/QUARANTINES/config_tmp.csv','rb') as csvfile:
And it seems to work fine.
Hope it helps
Cheers
Mike
