Forcing viewport redndering engine
For compatibility issues, we need to force users to use Viewport 2.0 with the 'OpenGL - Legacy' rendering engine (as it's in preferences->display->viewport 2.0).
We're in a studio situation, relying on user preferences is not sufficient. Any suggestions on how to force this at startup via a script, cmd-line option environment variable, etc... I can't find any documentation on it.
Using maya.cmds.modelEditor doesn't work as the only options are: [u'Viewport 2.0 (OpenGL)', u'Default Quality Rendering', u'High Quality Rendering', u'Stub Renderer'].
Cheers,
Jesse
Hi Jesse,
I think what you are looking for is the following mel script:
setRenderingEngineInModelPanel "OpenGLLegacy"
Had to force my users to use the directx11 rendering engine over here and this was the solution
cheers!
Thanks, that led me in the correct direction.
I'm using
 maya.cmds.optionVar( stringValue = ( 'vp2RenderingEngine' , renderingEngine    ) )
to force the rendering engine. If it's called in the userSetup, Maya doesn't need to be restarted. If Maya has already finished launching, it will require a restart. Setting the optionVar directly avoids the restart prompt.
It takes one of the following values: 'OpenGLLegacy' , 'OpenGLCoreProfileCompat', 'OpenGLCoreProfile'
If you give it any other value it defaults to OpenGLLegacy
