Maya 2016 PySide import issues
agovela
agovela
We're evaluating to upgrade form 2015 to Maya 2016. But unfortunately all the scripts that rely on pyside won't run in 2016. I get the following types of error messages:
DLL load failed: The specified procedure could not be found. #
I can import PySide with no problem
but I can't do somethig like: "from PySide import QtGui, QtCore"
# Error: line 1: ImportError: file <maya console> line 1: DLL load failed: The specified procedure could not be found. #
Any ideas what changed form 2015 to 2016 regarding PySide?
Thanks!
you are quite likely mixing up two version of Qt/PySIde
Cannot mix incompatible Qt library (version 0x40701) with this library (version 0x40702)
ImportError: DLL load failed: The specified procedure could not be found.
check whether you have PySide installed on the system and if it's so, just remove it.
L.
