Announcements
Maya 2016 MPxHwShaderNode glGeometry/geometry not called
I have created my own custom shader inheriting from MPxHwShaderNode -- and the virtual functions geometry / glGeometry never get called. -- However the compute virtual function does get called.
How do I get these geometry/glGeometry functions to get called?
Here is a snippet of the header file:
class HwShader : public MPxHwShaderNode
public:
void postConstructor() override;
MStatus compute(const MPlug&, MDataBlock&) override;
MStatus glGeometry(const MDagPath& shapePath,
int glPrim, unsigned int writeMask, int indexCount, const unsigned int* indexArray, int vertexCount, const int * vertexIDs, const float * vertexArray, int normalCount, floatArrayPtr normalArrays, int colorCount, floatArrayPtr colorArrays, int texCoordCount, floatArrayPtr texCoordArrays) override;
MStatus geometry(const MDrawRequest& request, M3dView& view, int prim, unsigned int writable, int indexCount, const unsigned int * indexArray, int vertexCount, const int * vertexIDs, const float * vertexArray, int normalCount, floatArrayPtr normalArrays, int colorCount, floatArrayPtr colorArrays, int texCoordCount, floatArrayPtr texCoordArrays) override;
int colorsPerVertex() override;
int normalsPerVertex() override;
int texCoordsPerVertex() override;
bool hasTransparency() override;
bool provideVertexIDs() override;
static void* creator();
static MStatus initialize();
MStatus bind(const MDrawRequest &request, M3dView &view) override;
MStatus unbind(const MDrawRequest &request, M3dView &view) override;
MStatus glBind(const MDagPath& path) override;
MStatus glUnbind(const MDagPath& path) override;
const static MTypeId typeId;
const static MString typeName;
//Snippet of initialize plugin
MStatus initializePlugin(MObject obj)
MStatus status;
MFnPlugin shaderPlugin(obj, "Shader");
// a classification for where the node will appear on the create menus
// of the multilister and hypershade.
const MString UserClassify("shader/surface/utility");
shaderPlugin.registerDragAndDropBehavior(ShaderBehavior::typeName, IugoShaderBehavior::creator);
status = shaderPlugin.registerNode(HwShader::typeName, HwShader::typeId, HwShader::creator, HwShader::initialize, MPxNode::Type::kHwShaderNode, &UserClassify);
cheng_xi_li
Autodesk Support
Autodesk Support
Hi ikeshet,
Are you using it with Viewport 2? It won't support VP2. If you want to implement custom drawing for Viewport 2, please implement MPxShadingNodeOverride.
Yours,
Li
I have tried using the MPxShadingNodeOverride as well.
It's draw call also does not get called.
I have tried switching the Renderer viewport to both legacy and VP2 -- and still does not work
class HwShaderOverride : public MHWRender::MPxShaderOverride
public:
HwShaderOverride(const MObject& obj) : MHWRender::MPxShaderOverride(obj)
MString initialize(const MInitContext& initContext, MInitFeedback& initFeedback) override;
bool handlesDraw(MHWRender::MDrawContext& context) override;
bool draw(MHWRender::MDrawContext& context, const MHWRender::MRenderItemList& renderItemList) const override;
static MHWRender::MPxShaderOverride* Creator(const MObject& obj);
MHWRender::MPxShaderOverride* HwShaderOverride::Creator(const MObject& obj)
return new HwShaderOverride(obj);
//This function never gets called
bool HwShaderOverride::handlesDraw(MHWRender::MDrawContext & context)
std::cerr << "Handles Draw" << endl;
return true;
MString HwShaderOverride::initialize(const MInitContext& initContext, MInitFeedback& initFeedback)
return MString("Autodesk Maya IugoHwShaderOverride");
//This function never gets called too
bool HwShaderOverride::draw(MHWRender::MDrawContext& context, const MHWRender::MRenderItemList& renderItemList) const
std::cerr << "draw" << endl;
MHWRender::MPxShaderOverride::drawGeometry(context);
return true;
In my Draw / Geometry call -- Even if I leave it blank / with just a print statement -- it stills draws the object and 2 never enters my draw call
Sigh.
After a long time -- I have figured out that I did not have the Material rendering set in Maya -- hence why nothing was being called.
Hi ikeshet,
I also tried an older code of mine from 2010 in Maya 2015/2016 and had the same problem.
So what do you mean by "Material rendering not set"?
Thanks a lot!
