Making connection to the next available multi-attribute index in Python.
morinnicolas8944
morinnicolas8944
I couldn't find a direct way to make a connection to a multi-attribute in Python when I don't know if there are connections already. I am trying to connect to a Set node's "usedBy" attribute, but it looks like its indexMatters flag is not set to false, so using "connectAttr" with "nextAvailable=True" fails.
I ended up using MEL's "getNextFreeMultiIndex" to find the next available index as shown below, but going to MEL within a Python script feels awkward and I was wondering if there was a more direct way to do it.
Here is how I am handling it now:
import maya.cmds as cmds
import maya.mel as mel
idx = mel.eval('getNextFreeMultiIndex "' + theSet + '.usedBy" 0')
cmds.connectAttr(myNode + '.message', theSet + '.usedBy[' + str(idx) + ']')
Did I miss a Python command that can handle this?
Thanks!
cheng_xi_li
Autodesk Support
Autodesk Support
I don't think there is a Python command available for it directly. Calling MEL in C++/Python is quite normal, it is designed to have some commands could only be called with MEL. maya.cmds is basically MEL commands and classes like MFileIO is a wrapper for file command with MGlobal::executeCommand.
Yours,
Li
kevin.picott
To add more information to this, maya.cmds is actually a Python binding to C++ code. Utility scripts, such as getNextFreeMultiIndex, are written in Mel and use some C++ commands to do their operation. Here's the source (which you can find in your install directory):
global proc int getNextFreeMultiIndex( string $attr, int $start )
	// We find the next unconnected multi index starting at
	// the passed in index.
	int $i;
	// assume a max of 10 million connections
	for( $i = $start; $i < 10000000; $i++ ){
		string $con = `connectionInfo -sfd ($attr + "["+$i+"]")`;
		if( size( $con ) == 0){
			return( $i );
	return(0);
As you can see there's nothing magically MEL about it, the implementer just chose to use MEL over Python for any number of reasons - they were familiar with the language, they copied from an existing script, Python hadn't yet been integrated into Maya.
Personally I prefer Python as it's more of a standard language and it is far more powerful. The above script could be rewritten in Python as:
def get_next_free_multi_index( attr_name, start_index ):
	'''Find the next unconnected multi index starting at the passed in index.'''
	# assume a max of 10 million connections
	while start_index < 10000000:
		if len( cmds.connectionInfo( '{}[{}]'.format(attr_name,start_index), sfd=True ) or [] ) == 0:
			return start_index
		start_index += 1
	# No connections means the first index is available
	return 0
Kevin "Father of the DG" Picott
Senior Principal Engineer
