Loop is giving an error
Why am i getting an error that says # Error: TypeError: file <maya console> line 46: 'int' object is not callable # .
leng = len(jointarr)
for i in range(leng):
    if i == 0:
       print("True")
    else:
       print("False")
mspeer
Hi!
Your script is missing important information:
1. There is no line 46
2. What is jointarr?
If i set jointarr to any string value the script works fine here.
there is line 46 it just a piece of the code, the snippet i put line 46 is where the for loop starts. jointarr is an array and it gvies back 3 or 2 depends on how many joints i selected so im just check the lenght of the array with len.
Just tried and it works something is up with range function for the loop i even used it on a different script panel and same error.
for i in jointarr:
     if i == 1:
        print("True")
     else:
        print("False")
mspeer
Hi!
Without a complete example the problem can't be detected.
Here this code works fine, when i define a valid value for jointarr.
Yup got it working all i did was just close maya and reopened it.
RFlannery1
My best guess is that at some point you made a variable named either "len" or "range".  This overrode the Python built-in function of the same name.  For example, the following code would generate a similar error:
len = 5
myList = ['aa', 'bb', 'cc']
print(len(myList))
When this happens, restarting Maya is the correct fix because the Python interpreter has to be restarted.  The main takeaway here: Don't use Python keywords as variable names.
