Locked file texture Python/Maya shadingNode
JohnSaleem3D
JohnSaleem3D
Community Visitor
Community Visitor
i am getting some strange result here using the shadingNode,
whenever i create a file node thro python in maya i get the color space locked and the color space drop menu greyed out , ex.
fileNode = cmds.shadingNode("file",asTexture=True, name = "dispMap")
please see image attached, however i get the usual expected result when i create the file node from the create shader tab in hypershade
mspeer
Hi!
You need a connection to Color Management.
fileNode = cmds.shadingNode("file",asTexture=True, isColorManaged=True, name = "dispMap")
Is there an easier way to set this up? Something built in the UI? Or do I just type that snippet of code in to the script editor ?
mspeer
Hi!
What do you want to do, what is the problem?
I am having the same issue as the guy in the original post. The color space is locking when I connect the output of 2D textures to certain nodes. I am trying to make sure the textures are in the RAW color space but after I set it and connect it to a 2D bump for example, the color space option box grey's out. Another example is me plugging in a roughness map to an AIStandard Surface specular roughness slot. Not sure if there is any way to fix this in the UI or if I need to use a script to unlock this. Albedo map is color map is unlocked and in the same AIstandard Surface / base color . I am baffled
mspeer
Hi!
1. It's not the same problem. This topis is about creating a node with a script not with the UI.
2. Please add an exact step by step instruction how to reproduce this + add an example scene.
(Here it works correct)
