Announcements
load texture into vertex color
I need help on how to store texture rgb values into vertex color mesh attributes. I've tried to do manually with "echo all commands" active with no results, because when I use artAttrPaintVertexCtx command, appear the paint tool, but the surface is not paintable instead when I do manually it works.
Thank you in advance for the help.
mcw0
You can loop through your vertices.  Convert to uvs and get uv position.  Then use "colorAtPoint" to get RGB values at that position.  Then use polyColorPerVertex to assign the rgb value to vertex.
Thank you, I will do some tests
