Announcements
load resources from a folder inside my plugin folder?
Good evening,
I'm shortly before releasing my plugin for everyone. I have created a folder named Circlelizer. In that folder, I have other folders called "html", "resources" and "themes". So how do I reference them correctly within my plugin?  I could just place all the resources etc. inside a Maya folder but I don't want to mix those files. It also doesn't look clean for me.
So my structure looks like this:
Circlelizer
  • html
  • resources
  • themes
  • circlelizer.py
So If I load the plugin while the folder is let's say on my desktop, the working directory is .../maya/bin. If I now would reference my resources inside my script like /resources/image.png it would immediately throw an error message.
Life
cheng_xi_li
Autodesk Support
Autodesk Support
Hi LifeArtist,
You can use MFileObject to get files from a relative path to the plugin folder. Like below:
	MString testLocation("./testFolder/test.txt");
	MFileObject fileObject;
	fileObject.setRawFullName(testLocation);
	fileObject.setResolveMethod(MFileObject::kRelative);
Yours,
Li
Thanks! It worked perfectly for me. I forgot to mention that I am developing using python.
So the correct code for python would be:
path = "themes/default-theme.qss"
fileObject = om.MFileObject()
fileObject.setRawFullName(path)
print(fileObject.resolvedFullName())
In case another one needs it for python 😉
Life
And of course you need to add:
fileObject.resolveMethod = om.MFileObject.kRelative
